Turbo backpressure gauge
Old 03-14-2012, 10:10 PM
I have a gauge for that
Atomic's Avatar
Default Turbo backpressure gauge
If I were wanting to add a boost gauge to measure back pressure on the turbine side, where would be the best place to put it? The heat is obviously a concern, so I need to ponder that some more. This is more for curiosity than anything else...
Old 03-14-2012, 10:37 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
As long as its before the wastegate the pressure should be constant. You will need to do like the diesel guys and use coiled up copper tubing to dissipate some of the heat before attaching the boost sending unit. Autometer PN 3224 is what you need then your boost gauge sending unit plugs right into that.
Old 03-15-2012, 08:36 AM
M&M Turbochargers's Avatar
yup just run a section of copper or aluminum tubing to disipate heat and switch to what ever hose you want and a guage
Old 03-15-2012, 09:30 AM
kbracing96's Avatar
I had one for a while. I just tapped the manifold right before the turbo for 1/8npt and put a 1/4'' soft copper tube about 2' in length that coiled around a few times with a nipple on the other end and ran it to an extra boost gauge. Worked good.
Old 07-22-2012, 09:40 PM
Atomic's Avatar
Coming back to this idea...just installed this:
Havent tested it yet, but the coils are down in the air flow so it should loose most of the heat.
Old 07-22-2012, 09:49 PM
How do I change this text
Wilde Racing's Avatar
damn thats alot of tubing.... BTW, you dont need that long of a tube. My first one was two or three feet, then my second was about 14" long. Both with steel tube. Most factory diesels run back pressure with about a 6" section of tubing. If you think about it, you only need to isolate the heat from the actual pipe not the temp of the exhaust gas. I also found you need a pretty small orifice to "clean up" the exhaust pulses..
Old 07-22-2012, 09:55 PM
Here was my two old set-ups...
Old 07-22-2012, 10:15 PM
Atomic's Avatar
I just went ahead and used all the was in the kit, not a big deal IMO. Im using a mechanical gauge, so I was more worried about melting the plastic hose on the other end.
Old 07-23-2012, 02:48 AM
GFYS and STFU
Spoolin's Avatar
Really interested in seeing the results of this.
Dusty what were your ratios again? Didn't you also do this with the STS?
Old 07-23-2012, 06:35 AM
Atomic's Avatar
This will really tell me if the T4 is too small after all! I hope its less than 1.75:1 backpressure to boost, otherwise I might be forced to upgrade...
Quick Reply: Turbo backpressure gauge
