Turbo backpressure gauge
#31
Mod with training wheels
Backpressure definitely robs power. I dyno tuned my truck last year and didn't know my quick spool valve was stuck closed, so it was only running through one scroll of the 1.10AR T6 housing. Started off making 595hp/615tq when I started at 10psi, and eventually tuned up to 16psi getting only another 30hp, but an additional 280tq. Kept tuning and tuning, took half a dozen pulls to figure it out lol. It did make 600hp at 3500rpms though
#32
Results, finally:
RUN 1
RPM 5200 5500 5800 6000 6200
Compressor Pressure [psi] 10 10 10 10 10
Backpressure [psi] 18 18 18 20 22
Intake boost pressure [psi] 8 8 8 7.5 8
RUN 2
Compressor Pressure [psi] 11 11.5 12 12 12
Backpressure [psi] 18 19 20 22 25
Intake boost pressure [psi] 9.5 8 8.5 8.5 8.5
RUN 3
Compressor Pressure [psi] 0 13 13 13 14
Backpressure [psi] 0 19 22 25 27
Intake boost pressure [psi] 0 10.25 11 11 11
RUN 4
Compressor Pressure [psi] 13 14 15 15 15
Backpressure [psi] 18 22 24 26 27
Intake boost pressure [psi] 12.75 13 13 13 13
RUN 5
Compressor Pressure [psi] 0 16 16.5 17 17
Backpressure [psi] 0 25 27 30+ 30+
Intake boost pressure [psi] 16 15 15.5 15.5 15
Good news is my new intercooler is doing a great job: At most only a ~2-3psi loss.
Bad news is backpressure is close to or over twice compressor pressure most of the time, kind of what I figured.
My testing methodology was to video my gauges for compressor pressure and backpressure, and compare that to manifold boost pressure on my hpt log. It should be pretty close, but as with any gauge and judging it by eye there is room for slight error. I feel this is pretty accurate and useful though.
Also discovered tonight the flex coupler going to my wastegate from the crossover has a pinhole leak and makes a nasty sound.
RUN 1
RUN 2
RUN 3
RUN 4
RUN 5
#34
...What sensor?
