Turbo Blanket?
#31
Originally Posted by vanillagorilla
You should actually do the exact opposite and run a richer idle, and retard your timing. If you have HPT, just use the scanner to command a rich AFR and pull the timing down while in staging. Then shut them off when you get to the line. If you have EFI Live then use the bidirectional controls to do the same.
#32
Adding fuel and retarding timing will cause the fuel to burn while the exhaust valve is still open, causing it to burn in the tailpipe thus heating everything up. It's the same principle that rally cars use to spool big *** turbos with tiny engines with manual transmissions.
I've done this many times as have others. Running the engine lean will just burn up the rings and get the truck hot in staging.
#33
I understand what you are saying, and that's fine to do on the line. I wouldn't do that while in staging though. I'm not saying running a 17.0 AFR, but a 15.3-15.5 vs a 14.7 isn't going to hurt it.
#35
Originally Posted by Sleeper04
I understand that part but was wondering about the performance aspect of it. For example, while waiting in the staging lanes at the track exhaust temps will cool, keeping the turbo from spooling up quickly once you get to the line. Would a turbo blanket help keep temps up so there is less lag once you get to the line? Sorry I wasn't more specific before.
#37
Der?!? I'll shut up now.
#40
Originally Posted by parish8
i haven't heard of anyone talking of a performance increase from blankets. it just helps keep the rest of everything under your hood happy. my wheel well melted and i was worried about my master cylinder. now i can put my hand right on the blanket after doing a run. they really work well.
there might be a slight performance increase if your airfilters are sucking under hood air and are able to get cooler air.
Hey Parish, ho wmuch of a decrease in underhood temps did you see with blankets? Thanks
lxcoupe
09-06-2017 08:24 AM
jtphelps289
09-11-2015 06:37 PM
06murder
09-04-2015 03:54 PM
