Turbo Blanket?
Old 06-14-2007, 11:27 AM
  #31
ChevyThunder17's Avatar
Originally Posted by vanillagorilla
You should actually do the exact opposite and run a richer idle, and retard your timing. If you have HPT, just use the scanner to command a rich AFR and pull the timing down while in staging. Then shut them off when you get to the line. If you have EFI Live then use the bidirectional controls to do the same.
You can do this if you want to waste fuel and cool down your exhaust, because that's all it'll do. Richening it up and pulling timing is going to drop your EGT's, which is exactly what he doesn't want to do.
Old 06-14-2007, 11:36 AM
  #32
vanillagorilla's Avatar
Adding fuel and retarding timing will cause the fuel to burn while the exhaust valve is still open, causing it to burn in the tailpipe thus heating everything up. It's the same principle that rally cars use to spool big *** turbos with tiny engines with manual transmissions.
I've done this many times as have others. Running the engine lean will just burn up the rings and get the truck hot in staging.
Old 06-14-2007, 11:58 AM
  #33
His concern is the truck cooling down in the staging lanes, and the turbo is 6+ feet away from the engine.
I understand what you are saying, and that's fine to do on the line. I wouldn't do that while in staging though. I'm not saying running a 17.0 AFR, but a 15.3-15.5 vs a 14.7 isn't going to hurt it.
Old 06-14-2007, 02:07 PM
  #34
Originally Posted by Sleeper04
What about for rear mount turbos? Will it help to reduce lag and spool faster?
Actually this was his original question/concern.
Old 06-14-2007, 02:13 PM
  #35
I understand that part but was wondering about the performance aspect of it. For example, while waiting in the staging lanes at the track exhaust temps will cool, keeping the turbo from spooling up quickly once you get to the line. Would a turbo blanket help keep temps up so there is less lag once you get to the line? Sorry I wasn't more specific before.
And I was reading from this. We are looking at two different things.
Old 06-14-2007, 02:29 PM
  #36
Der?!? I'll shut up now.
Old 06-14-2007, 02:32 PM
  #37
Don't feel so bad. Someone was posting up in the Duramax forums about a cam swap gone wrong, I stated that it was WAY TOO much duration for the engine, not realizing it was a diesel. I felt like I had for brains.
Old 06-14-2007, 03:51 PM
  #38
Sleeper04's Avatar
Sorry, didn't mean to cause an issue but I appreciate all of the feedback!!
Old 06-14-2007, 03:57 PM
  #39
No problem. I'm having an off day today. Hope you got at least a laugh out of it all.
Old 06-15-2007, 07:46 AM
  #40
Lord Aries's Avatar
Originally Posted by parish8
i haven't heard of anyone talking of a performance increase from blankets. it just helps keep the rest of everything under your hood happy. my wheel well melted and i was worried about my master cylinder. now i can put my hand right on the blanket after doing a run. they really work well.
there might be a slight performance increase if your airfilters are sucking under hood air and are able to get cooler air.
Hey Parish, ho wmuch of a decrease in underhood temps did you see with blankets? Thanks
kha4079
10-29-2018 04:38 PM
lxcoupe
09-06-2017 08:24 AM
jtphelps289
09-11-2015 06:37 PM
slowswb
09-05-2015 02:27 PM
06murder
09-04-2015 03:54 PM
Quick Reply: Turbo Blanket?
