Turbo Blazer to be UNTURBO'D!
well my turbo is taking a **** on me so its getting sent out for a rebuild
im getting bigger compressor and turbine housings going to a
60-1 compressor housing, with a .83 a/r turbine housing
also i am selling all of my rearmount stuff and i already have a battery relocation kit.
the new set-up will be-
cometic Head gaskets
ARP head studs
1.6 RR's
taurus e-fans
Reinstall my devils own 2stage meth kit.
EIC (extra injectors)
Hptuners 3bar SD
Tial 38mm W.G.
Flipped stock manifolds and 2.5" crossover.
3.5" DP to a full 3.5" exhaust
3" boost pipes
3000stall converter
all billet servos
B&M tranny cooler
Ford 8.8" rearend
possibly a cam and headwork..... goal is 400whp on stock bottom end
ARP head studs
1.6 RR's
taurus e-fans
Hptuners 3bar SD
Tial 38mm W.G.
3" boost pipes
3000stall converter
all billet servos
B&M tranny cooler
Ford 8.8" rearend
Originally Posted by WJ MARK
Sounds like you have your work cut out for you. Good luck with the new setup!
if things go as planned im prolly gonna be able to put a built bottom end in the beast bye the end of summer (JE 8.5:1 pistons, Eagle rods, Cryo'd crank, 4-bolt mains, ARP hardware, balanced) and go for 550+whp. might need a T70 w/ .96 a/r for that
some pics of the set-up right now.-
nice oil pump i run one that looks identical. Mocal oil pump: http://www.racerpartswholesale.com/mocal1.htm
Just curious if you've had any problems with yours?
