Turbo Daily Build Thread
#101
Just an update. Fuel pump went bad somehow. Went ahead and swapped in a Walbro 450. Fuel pressure is holding solid. Also bought HP Tuners Pro and Atomic has been doing an amazing job of getting my tune dialed in. This has been working out well due to my lack of time to meet up with local tuners. There is an issue right now with a lean spike after PE. There are a couple threads on HPTuners forum about a fix with beta called "Desoot" mode.
Next step is to install a flex fuel sensor and go from there!
#102
Alright guys. Sorry, I haven’t been on here in a while.
The Walbro 450 has been running great. I’ll post some pictures below. I basically did a Venturi style setup, don’t mind the redneck zip tie method, i was in a bind. It runs great all the way to E. I just don’t do any significant pulls from less than 1/8 tank.
The truck is running on 7 psi still but with a flex fuel sensor. I was running E-85 for a while which made a very noticeable difference in the performance. The truck has been running great and just drove it from CA to TX and we just drove it to GA for the holidays. It has been getting about 17 mpg on the highway on gas and around 8 mpg city on E-85 (HA!)
The only other new part is the driveshaft. I blew it doing a highway pull so i upgraded to a Texas Driveshaft Specialists 2-piece.
#104
Hey man. Still way behind you! I’m still running 7 psi. I want to do gears and locker before i keep turning it up. I’m worried about exploding my G80 and breaking everything else. I get nervous everytime i do a dig.
#105
i'm not sweating it until i have too. stock rear axle and rocking over here.
Nice job on the pump. Does it move much with out the bottom attached? Maybe some fuel cell foam to keep it more solid?
what is your FP at cold start, warm idle and WOT? You only swapped pumps right? stock lines, connections, rails, etc..
#106
Fuel pressure is set at 58 and doesn’t move at all. My fuel rail mounted pressure sensor reads differently than the PCM after running for a while. I think i have a heak soak issue with the sending unit or it is not ethanol compatible.
Stock everything except the pump.
#107
Interesting but im not shocked. Is your truck FPCM equipped? Im guessing not because its not an OEM Flex truck. Im still poundering the idea of swapping my stock flex pump with a 450 and seeing what happens. Currently, cold start and WOT the FP would increase to 58 psi. idle and cruising would stay at 43psi.
#110
They are Speedhut.
