Originally Posted by MrHorsepowerLSx
(Post 5445908)
I run an ALKYCONTROL meth kit, and straight VPRacing M1. It’s like $30 for 5 gallon pail. It’s function is multipurpose. Cool the intake charge Remove heat from the combustion chamber Provide a higher octane in the cylinder (meth should not be used as a compensation for fuel) it is used in conjunction with fuel. Help resistant knock and detonation I have a little more then a gallon capacity, actually the washer fluid reservoir is my meth tank. So depending on how much boost I hit will determine how much meth to spray. Also you don’t drive in boost 24/7 so depending on your driving habits will determine how often you need to refill the reservoir |
Can someone address the area ratio question?
Also Tig's question about hot side tubing is a good one. I know a little bit about the effects of pipe diameter on flow rate (velocity) vs pressure, at least in pump and piping systems (I'm a power plant operator). Though how that fluid dynamics theory applies to hot exhaust gas movement and turbo function, I'm not sure. |
Originally Posted by Choda
(Post 5445850)
Trick turbo stage 2 kit. One thing it doesn't get into is the ratio of water/meth. Still learning... |
Proper “ratio” is 51/49 water/meth Really as close to 50/50 as you can get. But I prefer straight meth. It works for my combo and I haven’t messed with other ratios lol |
Originally Posted by Northeastconfederate
(Post 5447391)
The best ratio is 100% meth. The only time a mixture is recommended is when tank volume is a concern since your overall usage will be less when used with water. Also you cannot ship more than 50% meth without it being hazmat, which is why you dont see mixtures higher than that offered. Best bet is to get a 5 gallon bucket from your local speed shop and refill it with 100% when needed.
On the meth, you can buy it local. New Egypt speedway sells it. Just call and see when the pump is open and they'll pump as much or as little as you want.
Originally Posted by wretched73
(Post 5447460)
You are over thinking the hot side. 2.5 inch cross over. 3 inch dp |
New question
I hope this thread continues to serve its purpose. I'm going to toss another question out there:
What about vacuum for the brake booster? Is this a non-issue because the motor still makes vacuum when not in boost, and the booster's check valve prevents loss of vacuum? I've seen some talk about switching to hydro-boost, but am not interested in doing that at all... |
