Turbo Escalade dyno results inside......
Old 03-12-2007, 11:06 PM
8ALTNG's Avatar
very nice numbers man now where is the video?????
Old 03-13-2007, 08:25 AM
thunderwagen's Avatar
Nice numbers bro. Are you seeing any spiking with the 38mm waste gate? Are you able to go any lower than 9# with the Eboost hooked up?
Old 03-13-2007, 12:51 PM
2toneblown's Avatar
No spike, and yes I started at 6#s
Old 03-13-2007, 03:29 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Originally Posted by 1SlowHoe
Those are damn good numbers.
I've never figured out why turbo set ups make HIGH numbers on the dyno compared to a S/C set up yet, they usually run very similar times at the track. Anybody care to explain that to me?
Same truck:
ie..6L @ 9 psi turbo makes 550hp/tq on dyno, runs 12.5 qtr.
6L @ 9 psi S/C makes 475hp/tq on dyno, runs 12.5 qtr.
Every watch the Livernois Escalade video? It murder the supercharged Escaalde by like 4 tenths IIRC.
Old 03-13-2007, 03:49 PM
single digit dreamer
parish8's Avatar
not sure where you guys are geting that the sc is quicker than the blower. lb for lb the turbo will kill the sc with all else being equal.
a 72mm turbo on a 6.0 will absolutly rip off the line with nothing more than a little brake stall wich is easy to do.
Old 03-13-2007, 05:50 PM
Double-L's Avatar
Well I have a Grand National with a 3400 stall and it takes a lot more than a little brake stall and I have a super charged 04 SSR 5.3 that kills the tires coming off at idle. Now the GN doesn't have a 6.0
Old 03-13-2007, 06:19 PM
2toneblown's Avatar
there is very minimal lag nor do i have to sit on the brake to build boost. It builds alot faster than I ever imagined. Its crazy fast and torque steers something fierce.
Old 03-13-2007, 06:22 PM
1slow01Z71's Avatar
Was that through the muffler or a cutout? You going to do anything else besides a built trans?
Old 03-13-2007, 07:17 PM
Was that on the 26's or did you throw on some stock wheels for that dyno?
Old 03-13-2007, 09:26 PM
parish8's Avatar
3.8 compared to a 6.0 with great factory heads and even high compresion in that case is really no comparison.
Quick Reply: Turbo Escalade dyno results inside......
