Turbo feed hose
Turbo feed hose
Turbo supply hose. Going to have to go from drivers side oil cooler line fitting over to pass side from top of turbo. Where are you guys getting these from? Thanks
I am using the HuronSpeed supplied AN hose with right angle end and 1/8NPT fitting for Turbo feed.
IF I have to replace that for leakage, or any other reason, I'll use Copper-Nickel brake line, and brass 1/8 NPT to Compression fittings.
Wolfy1969 (Today)
