Turbo Intake Manifold options
#21
You could just unhook your boost controller and run off the spring with each intake to measure airflow/boost loss. Then hook it back up to test at an even boost level. I think it would be interesting to compare the results from each set of data.
#22
I got a mustang dyno locked in for this testing, but like I said it will take some time to do these swaps...time is limited. I may have to take a spring out of my gate to go as low as 10, but I can work it out.
Just need a fast manifold now.. Who's going to step up?
I got dibs on
Fast makes best power..
Pro-flow close second, maybe same peaks or more, but not best curve)
NNBS
NBS
I got dibs on
NNBS
NBS
#25
I agree and like it better than the Edelbrock pro-flow, but I don't think they make it for cathedral port heads yet? I honestly don't see either outperforming the Fast under the curve where it matters for our trucks though.
#26
Alright so another issue im thinking of is, the size of the motor itself. 4.8's , & 5.3's are the small motors so would these intakes FAST, Vic jr., the Holley Hi-Ram, and what other intakes people are using still make decent numbers on these motors as the bigger cubed motors?
#28
well thats what im saying i guess. The bigger motors gain more than a 4.8 and 5.3 would most likely so would one of these intake listed actually be worth the money switching to???
#29
I AM A MOTHERF*CKER
IMO the holley will be in the same range as the PRO FLO XT. FAST > vic jr... A fully ported single plane MAST (which is light and day better than a Vic Jr) was < 30 hp ahead of a FAST 102 (test mule was a 468ci IIRC).
If I am ever able to get back in the shop and put BRT back together, I'll likely be running a ported FAST (but maybe a non-ported one too), unless I can't move some parts and budget decides me...
