turbo... MAF or speed density?
#24
How do I change this text
yep, quite a feat for the gm engineering team...
No the fuel in the wet shot helps keep all the cylinders burning equal...
#25
9 Second Truck Club
Afford, my truck, a new crew cab, bike, and have money left for restoring the charger? I dont think so.... It's going to be tight even with selling my truck. Plus I want to have the first LS powerd mopar s475 charger (with a five inch down pipe)
#27
9 Second Truck Club
Yes sorry the VE table. My fuel system is maxed out, and I haven't messed with the fuel curve for a while. My low, and high boost tune is the same just high boost runs meth. All I have done lately is turn the boost down 2PSI and pull 4* of timing, when I got to Ca.
#28
1 Post
Real benefits of the maf is if you are going to be changing temperatures and altitude. When the maf fails out at whatever level of airflow it fails at.. whatever the current tune is.. it can go into SD and make up for the flow. There are ways to make the maf work. I am definitely not sold on a 2 bar or 3 bar tune if you ever leave your happy place.. meaning if you start driving around at different temperatures and altitudes you will run into some issues with the truck going rich or lean depending on the DA. I know alot of guy's here hate the Maf but I know with most driving when you are not in boost it is a huge driveabilty increase to have the maf there when you need it. It can be made to work to your favor it just takes more time on the tuning end of things. While 2 bar tuning is "simpler" making it act more like a stock vehicle at all altitudes and all temperature conditions is a much bigger challenge without the maf.
