Turbo manifold idea...
Im working on some new manifolds for my truck. I built my originals out of 18/16 gauge material and that lasted about 4 weeks. Im going with the Mcmaster 1.9" elbows there made out of 10 gauge stainless. If you look I have the firing order marked in the middle of the block but anyway Im pretty much connecting cylinders/primaries 1-7, 3-5, 2-8 and 4-6. The exhaust pulses are only one stroke away from each other so that should make the turbos spool fairly quick. Heres the basic drawing... Ill try to get some real pics up in a week or so.
How do I change this text
Nice diagram, I'm not sure but wouldn't the exhaust flow faster if you went. 1-5, 7-3, 8-6, 2-4??
That would separate the left bank by five and the right bank by 3 equally for each side of the turbo flang.
Basiclly it would fire: yellow left, yellow right, green left, green right, yellow left, yellow right, green left, green right. Just a idea.
Originally Posted by ColtSteele
Im curious to hear how it works. I also want to throw a few ideas by you on something I've been working on. I'll PM you later if you dont mind.
Thanks
Thanks
Originally Posted by duwem
I dont get it, why split them up, you want the least amount of pulsing into the turbo, and you want all the air to go into the center of the exhaust inlet, not one side?????
So you think this might work out beter?
or you could just run 8 turbos then no fancy MS paint diagrams are needed
