Turbo my truck??? beginners questions
#21
I think what the Tech guys like is a looser stall to get the rpm up enough to build bust, and tall gears to really load it, is the best setup. You need rpm to get enough airflow to spool the turbo. I agree that tight stalls suck, but I think high gears will defiantly complement a loose stall.
#22
single digit dreamer
for me it boils down to a turbo works well on about any set up. you can have any gear and it will run well. a wide range of cams and it will work prety good. little or big exhaust and it will work ok.....
#23
It seems kind of like a win-win situation, because a stall will be looser with higher gears. Combine that with being able to build more boost on the line and you'll be able to leave higher in the rpm band.
5.3lSilverado
25
08-29-2016 12:48 AM
lxcoupe
08-15-2015 06:13 PM
