Turbo oil drain discussion?
Allen clean stop for sure. The straight fitting is for the turbo.
(we can change your kits fitting arangment yea)
BlackGMC
if you have any breathing to the outside air, you should not be able to pressurize the crank area. To much blow can make a huge oily mess at the breather thou.
Rick
BlackGMC
Rick
9 Second Club
Originally Posted by FarmTruc
IMO, here is the easiest place to put the return line. Not every one has a right angle drill and to fit a convential drill in that area is a pita, plus you need a short drill bit.
Specifically for the trick kit, I replace the fitting from the turbo with a straigth piece, then the hose comes down and over right into the front of the oil pan.
The brass fitting has about a 1/2 hole and we use high pressure, high temp, oil resistant hose.
I've drilled many holes with the pan on and off. As long as you're careful and use a lot of grease, no metal will get in the oil pan.
Hope this helps,
allen
Hope this helps,
allen
i have mine on the front like that as well...damn near level with the turbo and no drain probs ONCE i vented the crankcase via the valvecovers
Performance Trucks Sponsor
Originally Posted by BlackGMC
I have a question I would like to throw out there.
I was wondering if boost/compression was pushing past the rings and pressurizing the bottom end of the motor, would that cause this drain line not to work properly? I am pretty sure the stock PVC system can handle a small amount of blowby but the extra amount created by FI might overwhelm the system..... Just a thought
The stock pcv isn't enough for even 5psi, we pull the hose going from the passenger valve cover to the throttle body and that's our vent. Or install a tiny kn filter ontop the oil filler cap.
thanks,
allen
High on diesel fumes
Ya, you will push oil out the turbo if you don't vent it.
thanks,
allen
thanks,
allen
I ran my passenger side valve cover vent to the intake tube pre-turbo since that will always see a little bit of vacuum.
Originally Posted by thunder550
Does that work? When you get into boost doesn't the throttle body see positive pressure on both sides?
We have ran that same hose over to the suction side of the turbo as well worked pretty good.
Originally Posted by TrickPerformanceProducts
I think Allen ment he pulls that hose off the throttle body. and installs a small filter on the hose.
Yeah that would make more sense. I didn't think that the throttle body bung was any good for anything once you put a turbo or s/c in front of it.
Thats where i ran my hose, no iisues as of yet
Noah Burns
09-07-2015 05:50 PM
