turbo oil restrictors....
Old 02-13-2009, 12:17 AM
eviltwin_1987's Avatar
i have nitrous jets coming in the mail for mine tomorrow. will put some pics if you want
Old 02-13-2009, 09:09 AM
Hunt&Fisherator
silver-mod-o's Avatar
Ordered one from ATP Turbo, 1/8" NPT male and female ends with a .065" orfice. It was only $14.00.... Worth it to me.
But the restrictor wasn't my oil pressure issue anyway, it kept dropping, and now my brand new motor is basically junk bearing issues after 500 miles?
Old 02-13-2009, 10:00 PM
took 5 min
https://ls1tech.com/forums/forced-in...l#post11049625
Old 02-14-2009, 09:47 AM
La Chicken G B N L's Avatar
i was having the same problem when i was running mobil 1 10-30 changed the oil to castrol 20-50 and that solved my problem. i am running no restrictor on my twin 67's, you can also check your o-ring on your oil pump make sure its not pinched or cut.
Old 02-14-2009, 09:53 AM
How do I change this text
Wilde Racing's Avatar
Originally Posted by eviltwin_1987
Yes that works, but it really doesnt seal up on the back side of the jet.... My way is better. tap for plug, drill hole in plug, screw plug in......
Old 02-15-2009, 02:14 AM
mine works great. super easy to change jets if need be. i wouldnt say either way is better. but you seem to think one is.
Old 02-15-2009, 10:24 AM
lol, did you see my ??
Old 02-15-2009, 04:16 PM
oh
Old 02-16-2009, 02:23 AM
sdimer350's Avatar
i used an allen head plug (like what is in a hub to hold the key stock on a hub and shaft assembly) just took the turbo into the hardware store and found one that threaded into the oil feed for the turbo, cant remember the size tho. and before anyone says "its pipe thread, that wont work" i kno its pipe thread and it works good. just get that plug, drill your desired hole in it and thread it in and ur ready to rock. i havent had an oil problem yet and im not very nice to my truck.
GXPJAY
02-13-2022 08:15 AM
05GMC4.8
08-07-2015 09:55 PM
Ls3silverado
07-31-2015 04:22 PM
Gadgetized
07-22-2015 11:55 AM
Mzay
07-06-2015 11:03 PM
Quick Reply: turbo oil restrictors....
