Turbo Oil Weight
Old 06-13-2012 | 01:53 PM
  #21
Ferocity02's Avatar
Definitely a wide range it seems. I went ahead and used M1 10W-30, it was on sale. Depending on how it looks when I change it, I might switch.
Old 06-13-2012 | 02:10 PM
  #22
nonnieselman's Avatar
I used M1 5w30 for years in mine with the turbo.
noticed the oil pressure was a lil lower than normal, so i changed to Delo 400 15w40 and we are good to go now
Old 06-13-2012 | 02:41 PM
  #23
02'Z71ONDUBZ''s Avatar
yea thats it, way to not be too lazy lol
Old 06-13-2012 | 02:57 PM
  #24
I've heard good things about brad penn oil and may try it. Ive always run Mobil 1 but switched to rotella T6 for the turbo truck after my buddy convinced me. Hasn't blown up yet and has about 200miles on it
Old 06-13-2012 | 03:06 PM
  #25
It sucks searching when im on the iphone
Old 06-13-2012 | 04:10 PM
  #26
black4.8's Avatar
Valvoline VR1 10-30 oil, might switch to 20-50 on next change. keep filter changed every 500-1000 miles and change oil every 2,000 miles. clean oil is where its at whatever brand you choose.
Old 10-22-2012 | 07:56 PM
  #27
Ferocity02's Avatar
Bringing this thread back for another question. For you guys running 40 weight or thicker, what is your oil pressure like? With 10W-30, mine idles around 50psi, cruises around 58psi, and redlines at about 80psi. I would like to run a heavier oil with the turbo but am worried about TOO much oil pressure. Also hoping to quiet the valvetrain down after my cam swap.
Old 10-23-2012 | 03:03 AM
  #28
Suburbazine's Avatar
I'm not turbo yet but I'm running 20w-50 VR1 and my pressure is about 55# @ 800, 65# @ 2800 and hits 80# at 4400 and holds. 20w-50 runs FAR quieter than any of the 10w stuff.
Old 10-23-2012 | 10:25 AM
  #29
with Delo 400 15w40 at idle on a cold morning its 60#. hot its 40# at ilde.
2000 hot its about 50-55, 6000 its up around 80.
cruising the coast couple weeks ago idling for 3 hrs in traffic with the AC blasting i saw about 35 at idle.
Old 10-23-2012 | 01:15 PM
  #30
Ferocity02's Avatar
Do you know what your oil pressure was with a 30 weight oil? I may try Rotella T6 5W-40 this round, but I'm not too comfortable with thinner oil when cold, especially if I'm trying to reduce valvetrain noise, which is loudest when cold.
