Turbo Questions
Old 11-09-2011, 01:03 AM
  #21
s1nners10's Avatar
If you have E85 in your area then your set!
1 pump in a good distance
Old 11-09-2011, 01:37 AM
  #22
nonnieselman's Avatar
Poor mans race gas for boost!
I plan on setting mine up for it if i ever get it put together. Im gonna attempt to do dirt drags with mine, its got a explorer 8.8" with disk brakes and 31 spline axles, aldan eagle coil overs. Hope to have a ladder bar style setup figured out soon enough.
Figured with the isky cam i have for it and a good sized turbo with a shot of nitrous it should get on down the track.
Old 11-09-2011, 10:26 AM
  #23
s1nners10's Avatar
Default s10
that it is.. i am just not a fan of nitrous though, i dont ever plan on using it.
Old 11-09-2011, 11:34 AM
  #24
I wasnt either till i tried it on my silverado. Dropped it from a 13.2@104 to a 12.5@111 with just a 50 shot on 6psi boost.
It was a rear mount and helped it come out of the hole a ton better.
Old 11-09-2011, 05:43 PM
  #25
s1nners10's Avatar
Default s10
you ever have meth?
Old 11-09-2011, 06:23 PM
  #26
02'Z71ONDUBZ''s Avatar
If you can't swing the E85 then meth would be a must for you. There have been several threads about different kits recently, check them out.
5.3lSilverado
25
08-29-2016 12:48 AM
08lambochevy
08-07-2015 11:42 PM
USMCvet0311
08-01-2015 07:45 AM
WICK3DxGATA
07-21-2015 06:59 PM
Quick Reply: Turbo Questions
