Turbo or S/C for 6.2L? Questions...
More than you will ever make, I have both a 04 SSR with a 122 super charger and a street car with a 66 b.b. turbo, They both drive great on the street and run good at the strip, The turbo car is a V6 and it night run in the 9's if I pushed it but runs mid to low 10's the SSR is 4880 lbs and run mid 11's and hopefully better in cool air, Guys I know that run turbos all run singles but one, One guy has a small block running E85 with a front mounted 106 and he makes over 1600 hp to the real wheels and runs 7.80's at 193 on drag radials, Car has full seats and full power, I would look into a pro charger to
check out post #10 before you put too much confidance in the 6L80E. Youre not saying your SSR has a 6L80E are you??
https://www.performancetrucks.net/fo...d.php?t=465259
yeah there is some budget...
Starting out Im not going to be putting much boost so itll just be the turbo(s)
and then when I get some tranny parts I will up the boost and probably need a full fuel system...
Then a forged bottom end when I get bored with that...
For just the turbo system... probably a $5k
I was thinking about sequentials but after researching them that would be a TON of R&D with VSV's and programming...
Would compounds work? or are they only used to achieve high PSI and not necessarily quick spooling...?
Lets narrow this down and see if I can get any turbo sizes...
Lets say I want TWIN TURBOS. What size would be good for:
-Quick Spool
-Around 900-1000rwhp potential (500-550hp now)
starting with a stock 6.2l V8, will eventually bullet proof it and the tranny and install a full fuel system.
I want to stay with Master Powers turbos, so part or product numbers would be helpful!
I would really appreciate the help! I have searched this site, googled, yahooed, and asked jeeves numerous times with no prevail. Thanks!
-Quick Spool
