Turbo setup question
Im looking to build a turbo kit for my silverado. its a mainly stock 4.8 (yea i know) and found a steal of a deal on a turbo. These are the specs on it:
.50 A/R Compressor
.63 A/R Turbine
3" Inlet & 2" Outlet
Compressor Wheel 3" Exducer , 2" Inducer
Turbine Wheel 2.2" Exducer , 2.58" Inducer
Would this be a decent setup for my daily driver? I dont know what kind of boost or power range would work best. The guy says it starts spooling about 3K rpm. Input would be greatly appreciated.
.50 A/R Compressor
.63 A/R Turbine
.50 A/R Compressor
.63 A/R Turbine
.50 A/R Compressor
.63 A/R Turbine
IMHO, way to small for even a 4.8 That's only about a 56mm turbo. Probable good for about 350hp.
The guy told me is was good up to 400 HP. I've got a stock motor wit a ported and polished throttle body now. I was gonna try and find a ls6 cam and yellow springs and put me a small Turbo. The turbo has 1500 miles on it and zero shaft play and I can get it for 60 bucks! I figured I could get it and use it with my stock set up and upgrade when i do the cam swap.
![Happy](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_stretch.gif)
