Turbo size advice for 408
Old 12-27-2007 | 10:06 PM
  #31
FMOS Racing's Avatar
I run a 1.30 A/R on-center hot sided T76 on my tow rig (very mild 393). It's an old turbo and crotchety compared to the GTS-series stuff. It's making somewhere around 850 crank hp based on weight and ET. I leave at about 4 psi and see about 18 psi peak. Friend of mine is making about 1200 crank hp on a tangential housing small frame T88 on a 408.
I'm personally not a big fan of a T70 because of the peak efficiency pressure ratio, though I understand that the Holset T70 has a different map than that Garret T70.
I personally think the optimum turbo for a fairly large displacement gas motor with moderate power goals is a .96 A/R GTS or GTSH series 76 because it will move a lot of air at relatively low pressure ratios.
Old 12-28-2007 | 08:57 AM
  #32
ludicrist2500hd's Avatar
Originally Posted by parish8
nice info. any comparisons on front mount cam swaps?
we did a swap from a stock 5.3 cam to an 01 z06 cam and gained 100rwhp at the same boost level. no spool time info though since we have a 5000+rpm stall. we got such killer results we had to ask ourselfs how much a 02+ cam would help or an aftermarket grind.
might have to do some serious cam swap dyno thrashing on our next project.
I'm building a front mount kit for the GMT900's and will test the cams out , the gains you got are great are you using a 5.3 with 243 heads or 5.3 heads ?
Old 12-28-2007 | 11:25 AM
  #33
explorer5.0's Avatar
TOTM: November '07
I would put an S400 on your 408. THis is a great turbo and is only $585. I can't post the link though because Majestic Turbo isn't a sponsor here.
Old 12-28-2007 | 06:17 PM
  #34
parish8's Avatar
single digit dreamer
it was a completely stock 5.3 with just valve springs, then the cam swap.
Old 12-28-2007 | 09:19 PM
  #35
Hawk179's Avatar
i am interested in how diferent cams would effect spool time. can you share any back to back cam swaps and how they efected hp and spool time?
spoiling is greatly effected by one thing on a camshaft. And its easy to play with spooltime and tricks to make it come on later or sooner. But there is a cost to everything of course.
R
TAPyvehc93
07-23-2017 11:54 PM
maxspeed05V
08-12-2015 07:29 PM
FlowmasterMufflers
07-30-2015 06:03 PM
bsn1989
07-16-2015 09:20 AM
jrplz
07-09-2015 01:07 AM
