turbo specs and info
Anyone know of a good source for turbo related information? This site seems to be the best of the best on information glad I found it. I'm looking to do a turbo build using the 5.7 hemi, I left it stock displacement which is 345ci I used a forged crank, forged I beams, and forged lower compression pistons. Everythings is now arp studs as well. My goal is to make a street/strip truck using a large single turbo or twins, I have found a lot of turbo out there with many different varations and need helping choosing the correct ar housing and size turbo. Any help would be apperciated or if someone can point me in the right direction that would also be apperciated. Also what are some of your guys favorite brands of turbos?
For turbo stuff give Forced Inductions a call they are a vendor on the LS1Tech sister site. You will probably need something like a S-80 depending on how much hp you are trying to make.
What are you going to use for tuning it?
Are you making your own kit?
I have either dialbo or sct for tuning options.
Yes I will making my own front mount kit.
Full weight wow that's about 5400lbs or maybe 5200 I'm 1000lbs lighter wonder why they didn't just shave some weight to make the 10s pass, I contacted diablo about some tuning I just need to find a local dyno shop so we can tune it.
