turbo stall converter
Old 11-18-2015, 06:55 AM
tim wellington's Avatar
Default turbo stall converter
getting my stall converter .re stall its a yank pt 3200 .push tires at 2300 go to 2600 on 2 step ANY ADVICE .THINKING OF 3000/3200 FOOT BRAKE. BASICALLY MAKING IT 3600 .GETTING Alantic coast converter to re stall
Old 11-18-2015, 08:24 AM
I have a gauge for that
Atomic's Avatar
Can you build boost at the line? How much is it slipping up top?
If the answers are "yes" and "less than 10%", then you are fine with what you have.
Old 11-18-2015, 09:13 AM
only builds 3 psi .lean out to 16-17.5 on 2 step 23 degress of timing
Old 11-18-2015, 09:15 AM
Atomic's Avatar
You want it richer to spool it on the 2step, not leaner. Also try pulling the timing back down there. Better brakes might be good as well...
Old 11-18-2015, 02:00 PM
Default richer
i was going the wrong way i keep going leaner
Old 11-18-2015, 07:30 PM
kbracing96's Avatar
If you're "pushing" the tires, then you don't have a converter problem... You have a holding ability problem. Think about it, you're making more power then you can hold back. So you want to make a LESS efficient converter so you have less power getting to the ground? I'd get better braking before loosing up the stall.
BTW, ANYBODY touches that Yank of other then Dave and he will void the 5 year warranty COMPLETELY! He gets pissed. And he won't sell you parts if it needs any. Ask me how I know...
Old 11-18-2015, 07:59 PM
Atomic's Avatar
Cant say I blame him... I reccommend hydroboost and 05+ front brakes
Old 11-18-2015, 08:40 PM
Truck Sponsor
TrickTurbo's Avatar
How do you know?
Old 11-18-2015, 09:52 PM
kbracing96's Avatar
Originally Posted by TrickPerformanceProducts
How do you know?
Lol, had a brand new tranny built for my truck and just wanted a quick cut and flush done on my yank. Had a local place do it and he found the lockup cluch warped. Tried to get a new one from him and he said nope and your warranty is now void! Ended up haveing to send him my converter and paying $275 to have it fixed.
Old 11-19-2015, 07:00 AM
Formerly ScreamingL
George C....'s Avatar
There are 2 ways to go about it....i go lean and timing where others like rich and low timing
3400-3600 for converter and your issues will go away....youll come out harder with more rpm
Quick Reply: turbo stall converter
