Turboing 4.3 S10
Turboing 4.3 S10
i already know a good bit about forced induction, just not much about it on an s10. and i just need to know a few things and for yall to make me a list please
first off this is for a 2001 V6 CPI motor
how much boost can a stock block hold?how much boost do you prefer to maintain driveability and reliability? What injectors do i need
im looking at buying a buddies 60MM turbo. can yall please make me a list of everything i will need to turbo this particular truck. i wanna do a rear mount turbo with a water to air intercooler. i also plan on alcohol or meth injection.
please help me and thanks in advance,
Chandler
Chandler
13 Second Truck Club
You cant change injectors on your motor unless you swap to the marine intake manifold. The block doesnt contain the issue of boost, nut the rotating assembly does. There are many people running 12-15psi on them just as LS guys do, but how long will it take it.
I think a good spot for the 4.3 with boost is 8-12psi. 6-8psi is the limit with the stock intake injectors. Add in an FMU and its okay to 10-12, but an FMU isn't the best idea to me.
good luck with injectors. you will need to swap the manifold for real injectors. we run siemen 60's. we used a marine intake for our build. we also used a mpt-70 turbo. have you thought about syty manifolds for the turbo instead of but mount. would be cheaper i think after you figure in oil pump and piping to butt mount it.
haha A LOW DIME beat me to it.
check it out!! https://www.performancetrucks.net/fo...d.php?t=442854 he blew the clutch apart at 6 psi shifting at 4500 rpm while pulling past a ext cab dodge with long tubes, full exhaust, intake, and tune on the 5.7l hemi.
sorry to hijack.
sorry to hijack.
i didnt even think about syty manifolds please see if your buddy still has them and check a price. also i had hear something about the marine intake but wasnt sure. 6-8 psi will be great for what im doin because i have an ls1 i want to build for a lot of boost but it will cost so much that im gonna do this and slowly build th ls so i can do it right
EDIT: He still has them, $200. Crossover and both manifolds.
