TVS loosing boost
Old 04-09-2010, 04:27 PM
Default TVS loosing boost
Wondering if some are having issues with their TVS.
I'm loosing boost at 4500RPM and up.
Pulley is a 3.3". Ussually I hit 5 psi.
Let's say I do a quarter mile run....
fiirst gear,hammer down, 5psi till 4500RPM,boost moves down to bout 2 psi.Shift at 5800RPM to second,after the shift,it jumps to 5 psi again,till 4500 RPM range,it drops again till 2,etc.......
I think it's the belt that is slipping.I'm running the factory TVS belt tensioner.
Wonder if the HD upgrade will cure the issue.
TVS was installed on truck about 4 months ago.Just started to notice it in the last couple of weeks.
If so,quinda weird that the belt is slipping at only 5psi setup.
What do you think?
Left a message to Brian,waiting for his opinion as well.
Thanks for now.
Old 04-09-2010, 04:47 PM
2nd fastest 5.3 ECSB
trever1t's Avatar
are you reading a gauge or looking at a graph in your logs? Some fluctuation I see as normal throughout the rpm range but I see ~1lbs variation maybe. Doubt it's belt slip with that big pulley but the HD tensioner is a much better unit IMO.
Old 04-09-2010, 05:02 PM
I'm looking at the gauge.Also if I had no gauge,it's noticable when the boost drops.
Was not doing that until last couple of weeks.
I know it's quinda weird with that big saucer on the blower.I wouldn't want to try a smaller one for sure.........
Are you running the HD on yours?
Old 04-09-2010, 06:50 PM
DrX
DrX's Avatar
If everything is OK, I wouldn't expect belt slip at 5 psi if I can squeeze 18 out of an 8 rib on dual 1900s. Where is the tensioner sitting at in its range of travel? Have any of the idler pulley bolts loosened up? No signs that the belt is walking on and off the pulleys (starting to cut through the belt between the ribs)?
Old 04-09-2010, 07:58 PM
Registered User
shanes04ss's Avatar
im new to the sc world but just throwing this out there.
Is your harmonic balancer pined?
Not sure but it was just a suggestion.
Shane
Old 04-09-2010, 08:10 PM
blownerator
BlownChevy's Avatar
Shane
Ding........
Old 04-09-2010, 08:11 PM
DrX
DrX's Avatar
Shane
If the pulley is not pinned, check that pulley bolt. Mine spun loose on the old Radix/5.3, but that was at more than 5 psi.
Old 04-09-2010, 08:14 PM
blownerator
BlownChevy's Avatar
It should not need it at 5 psi......but stranger things have been known to happen.
Old 04-09-2010, 09:34 PM
I can get a new crank bolt and install it.
It was removed at least 2 years ago............
Thanks for the suggestions everybody.
Will try it first and let you know.
Brian never returns my calls anyway........
Old 04-13-2010, 07:04 PM
Got a new crank bolt.I also ordered a ATI crank pin kit.I might as well do it at the same time and be done with it.
Actually,the blower puller is a 3.4" and not a 3.3" that I'm running on it now.
Quick Reply: TVS loosing boost
