tvs1900 shreading belts...6psi
ok so iv had a few radix. and this is the first tvs iv had. now its got a 3.2 pulley and a interv. west crank pulley but im only using 6rips. now iv had the truck for 1 day and been thro. 2 belts? iv drove it hard but damn iv never had a iss. at this low psi. what could it be?? too be damn sure i dont have to run 8rips at 6psi.
than ks for all the help.
He is asking you where the tensioner holds the belt. If the tensioner moves two inches with a wrench, when there is no belt on it, from putting no pressure on the wrench to turning it as far as it will go. That is its range. Then put the belt on and see where the tensioner sits. Is it towards the loose side, tight side, or middle?
I agree with 03sierraslt, the tensioner should be the first thing you check, not your driving style. And by the way, it most likely happens when you let off the throttle from WOT, not at WOT.
