tvs1900 shreading belts...6psi
Destroyer of Transmissions
Pulley alignment is the most likely cause or balancer is spinning on the crank. Check for a loose balancer bolt. Had that happen and it cost me 3 tensioners and a few belts before I figured it out.
The HD tensioner is not really an option. It should be part of the basic kit. Tensioners seem to be the one part of the Magancharger line-up they skimp on. I have no idea why.
My 112 tensioner on my Tahoe had many issues, the tensioner on my Maggie GTO had to be "Upgraded" and now I hear the TVS tensioners are crap unless you "Upgrade" to the HD.
Don't know if this helps or not, but my tensioner is 8 rib and the 6rib belt is running on the middle 6 groves of the tensioner pulley. I've had some form of Maggie on this truck for 75K miles. Most of those miles with 2.6 or 2.8" blower pulleys. The only belt issue its ever had was when the blower pulley was installed backwards (way out of alignment). Other than that, never broken or thrown a belt.
Alignment and tensioner slacking are the 2 usually culprits for belts spreading or coming off.
Baltimore Whore
That is incorrect, the belt should be on the back 6 ribs and the front 2 should be open. When they built the 8 rib stuff, the add 2 ribs to the front of the pulley, not one on each side. I'm currently running a 6 rib superchager pulley and belt on my truck with the rest of the drive 8 rib. It's like this now cuz the size blower pulley I want to run I only have in a 6 rib but am having a new 8 rib pulley built.
