Twin Berserkers
#164
See: this post but instead of a milodon pan, I went with moroso
https://www.performancetrucks.net/fo...&postcount=156
The single oil pump couldn't handle the boost
#165
I exposed the crank to do some visual checks (first time I've pulled anything apart since the build). I don't run a girdle -- there was nothing available when I did the build -- and I don't see anything in a quick check now - do you have a link? I'll probably add one on the next rebuild though.
#168
Almost ready to put it all back together.
New twin oil pumps mounted.
New twin remote oil filters mounted.
New oil pan 85% completed (haven't put in the oil level sensor or repainted it).
I keep screwing up ordering the damn fittings... Hopefully I will make the lines before Thursday.
Now if this damn snow will just melt... Mabye I can mount a high hp snowblower in front of each rear wheel
I've also run into a hug problem with the coating. I will post more as I can, but there's some down time in my future to allow for recoating almost everything.
