Are you going to run the second pump continually or off of a boost referenced hobbs switch? What size wire are you going to run for power to these pumps?
I will have 1 pump running continuously and the second pump and each BAP will come on at 3#s. twin 14 gauge in the tank and 10 gauge outside the tank
What plugs out of a Corvette C5 are they, is what I am asking.
They are the power, ground for pump and power and ground for the sending unit. You buy the whole pig tail and connector so that you can make them run whatever you like from Racetronix.
