Twin Turbo Build....
Old 06-28-2009, 08:47 PM
  #31
chevrolade's Avatar
thats a badazz setup,NP FTW
Old 06-29-2009, 05:53 PM
  #32
11 Second Club
Phantom's Avatar
turned out real nice guys. how much did the blankets help? where did you end up putting the coolant reservoir? or can i just not see it there?
Old 06-29-2009, 06:52 PM
  #33
Performance Trucks Sponsor
FarmTruc's Avatar
Thanks,
Blankets are a must on this setup, helped out a lot on the single too, definitely recommend it.
We used a small hotrod 3" by 12" cylindrical reservoir for the tank, it's mounted next to the radiator, like the old hotrods have.
Hitting the track this wed.
Old 07-02-2009, 09:57 AM
  #34
FarmTruc's Avatar
Did some initial tuning on the dyno yesterday, over 638hp on 10psi!
100shot went over 700hp.
15psi will be max on this setup, I think we can reach out 800hp goal.
later,
allen
Old 07-02-2009, 11:42 AM
  #35
Truck Sponsor
TrickTurbo's Avatar
15psi only @800 ? 100 shot should have got you close to 750 area?
Old 07-02-2009, 02:12 PM
  #36
FarmTruc's Avatar
I didn't say I did an official dyno, I just took note of what it was laying down while tuning.
So, 800hp from a stock cube 6L? What is so far off about that?
I know ppl want to see outrageous numbers, but you're only asking for 50hp more lol, it's not like it's 200hp off.
Like I said, I was only tuning it and just took note of some of the numbers I recorded, and I never took the truck over 6K rpms during tuning.
geeez,
I guess if I had posted it made 800hp, nobody would have said, "800hp only" " I would have expected at least 875hp"
This isn't directly towards you Trick, but it's just nuts how someone posts hp numbers and most of the time it's not what the forum wants, or when someone posts their cam grind, the comment is "well, you should have gone 114" or "I would have gone 2degs less on the intake" LMAO!
Once I'm done tuning and start messing with the timing more and testing it out, it'll lay down over 850hp!
Old 07-02-2009, 02:31 PM
  #37
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
850 on nitrous or all boost?
Mic ought to have a good time that, time to tub the *** end
  #38
fastnblu's Avatar
Originally Posted by FarmTruc
Got it all done, well 99%. We need to finish identifying the spots that will get hot, reroute the spark plug wires, then take it to the track Wed.
Blankets function to retain heat or remove from engine bay? Perhaps I missed it.
How true. Awesome build. So Wed. came & went; track details?
Old 07-02-2009, 02:42 PM
  #39
ducky's Avatar
later,
allen
ONLY 638 HP? Must be the tune...
Old 07-02-2009, 03:47 PM
  #40
Truck Sponsor
TrickTurbo's Avatar
geeez,
WOW Allen I think you took my comments as a putting yall down. not in the least I was asking a question nothing more nothing less.I hope mine will put those numbers down once I can get it running and tuned.
Quick Reply: Twin Turbo Build....
