Twin turbo header problem
#51
You'd think a Tahoe/Suburban/VHO/4WD/AWD truck would have been available. Any of them with torsion bar suspension and a steering gear box instead of a rack and pinion would have given them measurements to fix the pipes. Nice shot of the front. Looks like it's going to be one impressive ride when done.
#53
breaking the Bank!
I like the synergy kit better but he doesn't have jigs to make more kits and the price isn't compareable to the HP kit plus when I talked to him he said I have to bring my truck, I am currently stationed in GA. I am not about to drive to CAlifornia but I am about to make some serious Horsepower out of my flexfuel 5.3!
#54
Serious power requires a serious Turbo system. If you look at the design of ours, you will see 1Khp is super easy to attain with it. Its the design of the headers and the other parts we use that make the system work, as well as make the price somewhat higher.
I might make the jigs soon, and I am planning on building a budget single kit for the truck guys.
R
#55
The truck is progressing slowly, just got the Greddy B spec 2 boost controller installed and plumbed up, waiting for longer lines to the hydroboost brakes to be made up, should be here by the weekend. then front panel back on and on to cold air pipework and intrcooler. then fit the snow performance kit.
I think I might make a coolant header tank aswell, I don't really like how close the original is to the turbo, move it back up against the bulkhead. then make a battery box for the rear bed. Then a Allen Nelson performance tune and we should be good to go.
#57
I've not had the plugs out since the manifolds have been on, looking at it I don't see any problems.
#59
A couple of pic's of where I'm up to with the truck. I had to cut the ally aframe on the front to mount the inter cooler and weld some ally brackets to the cooler and make a box section frame and bolted them together, I've never done any aluminium welding before, so that was a steep learning curve.. I think the radiator on the SS's might be a bit wider than the one that HP performance built the kit on, I had to squash a section of pipe to get between the rad and headlight I squashed a short piece of straight pipe then cut a 90 elbow in half and squased the ends welded the all together and that got me round the corner.
progress is slow but I'm getting there
