Twin turbos on 8.1/496
Old 09-26-2008 | 09:07 PM
TieRod's Avatar
That purdy sweet!
Old 09-26-2008 | 10:09 PM
Silver_TransAm's Avatar
11 Second Club
Indeed! Now it just needs some forged rods and pistons with some head studs to crank up the boost.
Old 09-29-2008 | 07:17 AM
Spoolin's Avatar
GFYS and STFU
Hey tie rod are rebuliding your burned down truck?
Old 09-29-2008 | 11:36 AM
kbracing96's Avatar
I'm pretty sure he got a new truck pretty much just like his old one.
Old 09-29-2008 | 12:42 PM
1989k1500's Avatar
Yea judging by his sig I would guess its going on the 03.
Old 09-29-2008 | 03:04 PM
Spoolin's Avatar
GFYS and STFU
Oh ok, I remember he got screwed by his insurance when his truck burned down so I didn't know what he ended up doing but apparently he went right back to work!
Old 09-29-2008 | 06:06 PM
TieRod's Avatar
This may help. https://www.performancetrucks.net/fo...d.php?t=425744
Old 09-30-2008 | 07:09 PM
Whippled 496's Avatar
I have never seen mine go past 7psi (stupid 2.3L blower). I thought it might have been higher but found out my gauge was muffed up when i swapped out to the new one. At 7psi and 15* i was seeing 400+rwhp and 500+rwtq. I would love to get 10psi into this thing cause with a little over 6psi right now...it moves *** for a large truck. From what i understand though, you will be held back a bit by the trany (if you have the Allison) as it hates the 5-4 shift under boost. Also, I have heard these pistons dont hold up to well beyond 8 or 9lbs. With some forged internals and a stge 4 or 5 suncoast Ally, you could have some serious fun though i bet.
Old 09-30-2008 | 07:17 PM
bpope's Avatar
Originally Posted by gnimelf4
I am interested to know if anyone has put twin turbos on a 8.1? I have 2001 2500HD with an allison tranny and am primarily looking for towing power. I pull a 48ft gooseneck with around 13,000 pounds. I'm not nessesarily looking for max power at high RPM (but wouldn't mind smacking a muskrat every now and then either) and would like to know what size turbos I should look for? How much boost is possible with the stock setup? Any guidence would help.
Not looking for max power...yeah right. I know how you are!
Old 10-02-2008 | 10:56 PM
11 Second Club
Your right about the tranny it sure does not like that for some reason.
On another note my pops has pushed his to 15psi with his twin rear turbos. Yes! 15psi when all conditions are good and for short periods of time of course. Low IAT's low humidity and so forth. His is all stock motor with an sd tune from Allen at nelson performance. It is usually on 8-10psi setting though.
Quick Reply: Twin turbos on 8.1/496
