twin whipple's?
#22
Originally Posted by smooth sierra
and a video of it in the boat, you can get a good look at how they are setup. Now these are carbed setups but the injected would be very similar I would imagine. http://marineassault.net/Running%20Hard.htm
#23
http://www.doublerperformance.com/dr...3781_5828.html
pricey stuff, this used in cdn $, about 60k usd
#27
Originally Posted by DanaliHD
I thought there was a reason why those twin whipples won't work on a car/truck?
#28
I don't see any advantage to running two small compressors over a single large one. Until a few years ago the 2.3L Lysholm was the largest compressor whipple had for kits. Back then there was no other choice past a certain power level but to run two. Lysholm then came out with a 3.3L unit. Whipple quickly redesigned the big-block hotrod and marine kits to use the larger compressor. With Whipple's own manufacturing they now sell a 5.0L twin screw compressor. With the availability of something that huge there no reason from a cost, packaging or performance standpoint to do dual small ones instead.
#29
wait. wait. wait.. so what is this all about??
the description says it will bolt up to most gen III small block. will this bolt up to my 03 denali 6.0??
http://www.w2wpowertrain.com/pc-96-7...-twin-kit.aspx
