twins and intake dyno today....
#31
Originally Posted by parish8
i guess what i would like to know is does a flat mounted tb right on the intake with a 90 above it flow better than what i have?
#35
...............sheet metal front inlet intake.................seriously though, i hope you get this all figured out.......
and yes I realize a victor style intake is used to eliminate the lean cyl conditions for better cylinder dist......
#37
I AM A MOTHERF*CKER
someone was posting up some pics of an adapter plate and a flat mounted tb but you are still going to need a 90 right on top of that so it is hard to say if there would be any gains.
#38
I AM A MOTHERF*CKER
i dont see how that test would help us learn anything. adding an extra 90 compared to nothing would have to reduce flow. i guess what i would like to know is does a flat mounted tb right on the intake with a 90 above it flow better than what i have?
Richard thinks so, and he can definitely explain all this better than I can
#39
Originally Posted by TurboBerserker
You don't necessarily need a 90. You can make a plenum box (I'm not, but you could). I've been looking for a corba head, but until one is made out of something that can handle the heat, I'll be using a 90* silicone piece.
#40
The way I see it, having the rectangle elbow after the TB increases plenum volume significantly. Plenum volume should be based on desired hp/tq, rpm, needed runner length (fixed in this case), engine size, boost, etc. I'm not sure what size plenum the Vic Jr. has, but I'm willing to be that elbow added at least doubles it. With a boosted motor plenum volume can be quite crucial, because its an additional volume that has to be pressurized. It effects throttle response, boost lag and the rpm at which peak hp and tq occur.
As for the elbow being a restriction, it's not as bad when you're under boost than when you're in vacuum, but like I said, it's an additional volume that needs to be pressurized AFTER the TB. With it being rectangle, there will be large Re's number spikes in the corners, but I doubt that would really effect power much, especially with the Re's numbers he has with as much boost as he's running.
To me, Turboberserker's setup seems the best and most logical. It provides a means of fixing the TB to the manifold without increasing the plenum volume too much for the runner lengths the manifold was designed for.
