Update on turbo setup on3 performance
AS you can see i had to move the coolant jug away from the turbo because the bottom hose was touching
SPark plug wires now touch the manifold hummm gotta figure this one out
top right u can see i had to cut and extend heater hose
dont think ill have any down pipe issues
Yes it leave towards the coolant jug, I'll try get a better pic later on today and so far I'm actually very pleased with the parts I've ordered from them. Everything mounts and connects nicely with the coolant adjustment
We normally just use the custom msd builder kit and make a few wires with 90 degree boots. Then loop them around, that is what works best.
Not sure when our production will be finished but we are currently making a custom plug wire set for the trucks. That way if you dont want to make a few custom wires yourself, we will have a complete upgrade set that will drop in. My guess will be 6-8 weeks though as we just got some samples made and sent them out to get quoted and manufactured
spark plug sleeves?
I've Used Spark Plug Fire Sleeves in the past and that's what I was going to use on my On3 build...is this good/bad I figured they would be fine, as on my Z06 they've held up over the past 3 years with my Long tubes.
Turbo manifold is going to get quite a bit hotter than a NA header. If the wire or sleeve is resting ON the turbo manifold I would strongly recommend making custom plug wires.
