Upgrade in a STS turbo
I'm pretty sure i will go with the STS turbo special from TBYRNE. As i read in the forums before it seems like the GT-67 is the right upgrade for the SS
What do you guys think about that? I plan on doing the install myself except the welding... The truck is a daily driver
Any testimonial would be appreciated.
Simon
Simon
I would recomend the 67,bigger injectors,and a pump. Just like Z06 dreaming says. I would also recomend a tune and a dyno w/af at a min. Best to make sure you do not have any fuel problems. As long as it remains a daily driver and you do not get too crazy on the boost you will be happy wth the 67. There is no question that you will have fun.
![Devil](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_devil.gif)
Simon
Simon
We did an SS and even with just the basic kit it made a big difference wrapping the exhaust. With a aftermarket stall, the truck will stall to 6psi.
It will kill an LS1 F-body.
Personally, I would change injector connectors and use the LS1 style injectors and use a green top 42lb.
11 sec. Truck Mod
go for it bro! your gonna love the boost! I would definitley do tuning, fuel inj/ pump, and upgrade the oil return line to a braided ss line for worry free oil system. HEY BILLY, Did you wrap the entire exhaust? from the y pipe back? do you have to worry about codensation rusting the pipe? sorry to get off topic.
11 sec. Truck Mod
Originally Posted by trtturbo
Tim, we wrapped it from just past the cats to the turbo. Any condensation that may be in the wrap is cooked off in a big hurry. We soak the wrap in water before we put it on too. It does help Tim!!
