Using silicone Hosing for intercooler??
Old 08-09-2005, 10:18 PM
greentahoe's Avatar
Originally Posted by PappyDan
well if your willing to spend $200.00 on new pipe already bent.
why not take it to a muffler shop, let them do it out of 2.5 inch pipe.
it will be coustom made for your set up, and later on down the road,
you can have it cleaned and crome diped.
i have already talked to a guy and got a price of 120.00 for 2.5 inch pipe,
4 sections for easy disassembly and a bung for my by pass valve.
it will be coustome made for my set up that will fit like a glove.
not sure I follow. I want it made out of 3" mandrel bent pipe. I dont think that an exhaust shop would do what Im wanting. Its quite a bit of work.
Im planning to have an exhaust shop make my Y pipe but thats only 2 45* bends and a collector.
Are they doing the measuring and everything for you? Are they using mandrel bent pipe?
greentahoe's Avatar
Originally Posted by 4.8T
why didn't you just use alluminum for piping instead of stainless??
aluminum is harder to weld from what I understand.
Old 08-10-2005, 02:54 PM
TURBHOE's Avatar
try this stuff called alumiweld it sounds like good stuff.
Old 08-20-2005, 11:02 PM
duwem's Avatar
aluminum is a big pain in the *** to weld. I would really get away from the rubber hose, not only does it look like ****, but it also wont last. As far as cutting stainless straight, i would build a jig for your saw/get a chop saw/bandsaw. that makes life a lot easier, and if you put some angle control on the blade you can make things more precise. if i ever do it i will do all stainless on the hot and cold sides.
$A_Money$81
03-27-2023 10:25 AM
Gadgetized
10-22-2015 09:06 AM
turbo6c3
10-05-2015 06:11 PM
old motorhead
09-29-2015 08:22 PM
lxcoupe
09-25-2015 12:36 PM
Quick Reply: Using silicone Hosing for intercooler??
