Walbro 255 swap
i just did the 255 install friday. not bad but i ran into one big problem ! my stock bucket had been changed to a cheap airtech before i got into it it sucked. as long as u still have the stock bucket its not bad at all. good luck.
i wish this thing had two socks on it. on on the pump pushed into the bucket and one on the outside of the bucket. nothing like stock. i looked at a delco at the parts store before i did it to make sure it was all the same as the post i had been reading and it was way wrong. but i worked at the parts store a couple yrs ago and the owner opened up for me after hours so i could get the sock i needed. i found one with more offset over what came with the walbro. its all working now but im also having problems withe the tune. me AFR its going up and down all crazy and dont know why...
Baltimore Whore
You can do a inline pump, it will work fine.. This a a half *** write up I did on the big bosch install. Naturally you will not have to cut as much of the bucket up.. Mind you this was done with my own stuff, not a kit that you buy, as I am sure they have diff ays of doing it..
https://www.performancetrucks.net/fo...k-pump-428535/
this is the walbro install i looked at before i did mine.
https://www.performancetrucks.net/fo...ite-up-465754/
05GMC4.8
08-07-2015 09:55 PM
