WARNING to Bosch 044 owners
Old 07-04-2010 | 09:48 AM
  #31
brent1976's Avatar
11 Second Club
I drilled 2 holes, put stainless bolts through the holes, and hooked 10ga wire to each side with a ring terminal end, and put a rubber washer on the outside to keep everything out.
Old 07-04-2010 | 10:07 PM
  #32
Calbo's Avatar
I'm about to replace my stock (dead) pump in the morning with a Walbro 20000169 255lph. I was told it is a direct replacement for the stock pump. Do I need to be concerned with the wiring?
Will my tune have to be adjusted since I have a boost-a-pump on there now?
Old 07-08-2010 | 09:43 PM
  #33
Atomic's Avatar
I have a gauge for that
So which two wires of the factory harness does this replace? The black (ground) and grey (power) ones?
Old 07-08-2010 | 09:53 PM
  #34
charcold-bowtie's Avatar
just run it from the back of the alternator, put it on a relay, and let the factory wire "trigger" it on
  #35
sureshot's Avatar
Yup, you got it!
Old 07-19-2010 | 12:58 PM
  #36
Atomic's Avatar
I just got my kit in today, is the red power wire long enough to go from the tank to the fuse box center? I have an extended cab and 15ft is kind of pushing it depending on how I route it...
Do you have any pics showing the connections to the pump?
Old 07-19-2010 | 04:49 PM
  #37
sureshot's Avatar
Yes, it is long enough. Sorry, I don't have pics of the connection to the fuel pump. It's just eyelets on the end of the wire that go over the studs on the pump.
Old 08-06-2010 | 03:33 PM
  #38
Atomic's Avatar
Where is the grey wire in the fuse box? Nothing is labeled fuel pump...
Old 08-06-2010 | 05:04 PM
  #39
sureshot's Avatar
Mangled did a write-up when he installed his. He took pics, and he points out where the wire is in the fuse box.
Old 08-06-2010 | 05:17 PM
  #40
Atomic's Avatar
I got it as soon as I realized the wire isnt directly beneath the relay
Quick Reply: WARNING to Bosch 044 owners
