Wastegate and manual boost controller questions.
Try this link,
http://www.hallmanboostcontroller.co...tions%20ld.pdf
Top port of wastegate - vent to atmosphere
Bottom port of wastegate - to bottom port of hallman
Front port of hallman - vacuum/boost source
Nope, it will raise it when turning clockwise.
Just to pull random numbers out of the air, lets say your spring alone will give you 25psi. When you add the boost controller fully counterclockwise, you are adding all of the boost seen in the intake to that bottom port which will have the gate opening at lets say 15psi. When you turn the hallman clockwise it lets less and less pressure though, as the boost on the bottom port lowers because of the hallman, your boost will raise.
