Wastegate and manual boost controller questions.
#31
MASS seller approved
Synapse here, 2 springs that cover almost any conceivable combo and 3 different ports you can use to adjust boost without even using a controller. 2 different seat sizes and No diaphragms!
#32
Just talked to JGS and they said to put the standard spring in there and run a hose from the top port to the compressor housing. Then run another hose from the compressor housing to the end of the mbc and the perendicular fitting out of the mbc to the lower gate port. I have nothing to the compressor housing port wise. I have a vacuum block that's fed off the manifold. He said that won't work as the wastegate should only see boost and no vacuum.
Any of you agree with that? I so I'll have to drill a hole in the compressor housing.
#37
First of all JGS wastegates are horrible. I am on my 2 JGS gate. The first gate melted all the internals and I lost all boost and a huge vacuum leak. Please buy a Tial gate and request whatever spring you would like. It is worth the 245 dollars for the Tial. You can buy the flange style or band style.
