Wastegate and manual boost controller questions.
Old 08-24-2012, 12:17 AM
  #41
Ferocity02's Avatar
There should be a flat spot to drill and tap on the compressor outlet. 1/8 NPT.
Old 08-24-2012, 05:11 PM
  #42
scooter k's Avatar
Not really a flat spot on my compressor housing!
Old 08-24-2012, 09:26 PM
  #43
Byrdman11's Avatar
You can put it any place on the boost pipes too.
Old 08-25-2012, 08:26 AM
  #44
scooter k's Avatar
There's the big square lug but that's all I see. Where does it need to be drilled?
Old 08-25-2012, 10:11 AM
  #45
black04's Avatar
It doesnt matter. anywhere on the output is fine.
Old 08-26-2012, 04:49 PM
  #46
scooter k's Avatar
I drilled and tapped it today. After having the compressor housing off and looking at it I'm going to have to either polish or coat it! Winter project for sure!
Old 09-19-2012, 09:44 AM
  #47
La Chochita's Avatar
its interesting how there are several ways to setup the wastegate to boost controller. ive read before to connect how was mentioned in this thread, while i have it different. My bottom port from wastegate goes to turbo outlet and its "t'eed" to boost controller, then from boost controller back to top wastegate port. Like this, I raise boost when i turn **** to the right....and less boost to the left.
Old 09-19-2012, 10:03 AM
  #48
nonnieselman's Avatar
Originally Posted by La Chochita
it interesting how there are several ways to setup the wastegate to boost controller. ive read before to connect how was mentioned in this thread, while i have it different. My bottom port from wastegate goes to turbo outlet and its "t'eed" to boost controller, then from boost controller back to top wastegate port. Like this, I raise boost when i turn **** to the right....and less boost to the left.
Yep!
thats how i have done it also..
Old 09-19-2012, 01:03 PM
  #49
Ferocity02's Avatar
This is a "two-port" method which uses controlled boost pressure to hold the wastegate shut in high backpressure setups. "One-port" uses boost pressure to open the wastegate, hence the opposite behavior with the controller. I think I have that right.
https://www.performancetrucks.net/fo...umbing-506387/
http://www.turbosmartusa.com/wp-cont...psi_MAY_12.pdf
GXPJAY
02-13-2022 08:15 AM
chopperloco
07-10-2016 10:45 PM
Razor
08-16-2015 11:39 PM
lxcoupe
07-15-2015 10:03 PM
Quick Reply: Wastegate and manual boost controller questions.
