wastegate size?
Turbos | Superchargers | Intercoolers | H2O/Meth Injection
wastegate size?
10-03-2012, 12:42 PM
kush killer
wastegate size?
trying to determine what size wastegate i need? how does one go about doing this?
Like
kush killer
Find More Posts by kush killer
10-03-2012, 12:59 PM
Atomic
I have a gauge for that
What engine? How much boost? What turbo?
Like
Atomic
Find More Posts by Atomic
10-03-2012, 01:02 PM
kush killer
cammed 5.3 76mm turbo and probably around 14-15psi
im assuming the saying "bigger is better" applys here?
Like
kush killer
10-03-2012, 01:03 PM
lglowe
What 76mm turbo?
And are you dump waste gate to atmosphere and how big of an exhaust are you gonna run.
Like
lglowe
Find More Posts by lglowe
10-03-2012, 01:05 PM
Atomic
The higher the boost the less wastegate you need...
a 38mm will probably be fine for that, but a 50mm wouldnt be bad
Like
Atomic
kush killer
to be honest not sure.. recomendations? i know exhaust would be atlest 3"
Like
kush killer
10-03-2012, 01:06 PM
kush killer
so maybe run like a 40mm or 45mm?
Like
2006 Silverado A/C acting up all of a sudden
17
419
Project Polar Bear: '05 Suburban 2500
Using a TCM-2650
320
58.9k
Building a turbo Suburban for towing
1k
1.9k
kush killer
10-03-2012, 01:21 PM
nonnieselman
you can run the 3" but id dump the wastegate to the atmosphere or run a muffler on it..
Like
nonnieselman
Find More Posts by nonnieselman
10-03-2012, 01:47 PM
o2camaross
what do think the hp limits are with 3" and the wastegate dumping into it
Like
o2camaross
Find More Posts by o2camaross
10-03-2012, 01:49 PM
nonnieselman
you just start getting boost creep.. and then it cant flow enough as it is so the boost keeps on creeping up from the backpressure..
i have no clue on the HP limits.
Like
nonnieselman
Posting Quick Reply - Please Wait
Quick Reply:
wastegate size?
The following errors occurred with your submission
Okay
Quote message in reply?
06:35 PM
