wastegate size?
But not when you open the exhaust Nonnie. You could use a bigger gate and so could i. I'm using the jgs 40? And the lowest boost I can make is 10 psi on a 6 psi spring. Has a lot to do with backpressure in the cross over and how well the exhaust flows post turbine.
Closer_2001
09-24-2015 09:15 PM
