wastegate size?
Old 10-03-2012, 01:51 PM
HIPSI's Avatar
I'd go with a jgs 50mm.. I've been down the road of having to small a wg and overboosting problems.
Old 10-03-2012, 02:26 PM
nonnieselman's Avatar
Im running a Tial 38mm and its been good to me ever since i used it on the STS kit years ago and now on my KBracing kit.
Old 10-03-2012, 07:35 PM
Laid Back
Beatdown Z's Avatar
I'm running a 38mm on my 5.3 and it can keep the boost as low as 7psi. At 14lbs a 38mm will do just fine.
Old 10-04-2012, 07:31 AM
kush killer's Avatar
cool, thanks for replys guys, found a turbosmart 40mm for a pretty good price so i think ill jsut swoop that up.
Old 10-04-2012, 07:32 AM
Originally Posted by lglowe
What 76mm turbo?
And are you dump waste gate to atmosphere and how big of an exhaust are you gonna run.
on3 perfomance..
Old 10-04-2012, 08:45 AM
the 38mm Tial is keeping mine around 5psi right now.
Old 10-04-2012, 08:55 AM
lglowe's Avatar
But not when you open the exhaust Nonnie. You could use a bigger gate and so could i. I'm using the jgs 40? And the lowest boost I can make is 10 psi on a 6 psi spring. Has a lot to do with backpressure in the cross over and how well the exhaust flows post turbine.
dsbodley
11-14-2015 09:46 PM
LSX-81-SIERRA
10-02-2015 07:05 AM
old motorhead
09-29-2015 08:22 PM
Closer_2001
09-24-2015 09:15 PM
Quick Reply: wastegate size?
