wastegate stuff...boost creep ect...
12 Second Club
my bov, boost gauge and wastegate are now all referenced off the one port on the side of the intake. ive done some research and i hear to run lower boost you need a bigger wg... so with that in mind im going to switch back to the 11.5psi spring and see if it holds steady.. im hoping it will since its a brand new wastegate w/ the 4psi spring.
-mike
Man if you can hold steady at 10psi it would be no big deal I would just leave it until you can have a bigger waste gate installed I have cranked mine up to 10psi a few times I will run out of gas before I wipe that silly grin off my face!
Hey Mike I talked to Brian at hinson supercars and he said your problem is definately the wastegate being to small he said you need to try the 44mm wastegate instead, and he said to feel free to give him a call for questions I would give you his phone # but I would probably get banned again!
