water wetter safe to use in Magnacharger's cooling system??
Old 09-12-2011 | 07:57 PM
McAllenSS's Avatar
Default water wetter safe to use in Magnacharger's cooling system??
Is it safe to run water wetter in the Magnacharger's cooling system? Will it hurt any seals etc etc? Thanks.
Old 09-12-2011 | 08:07 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I use it. You won't have any issues.
Old 09-12-2011 | 08:44 PM
moregrip's Avatar
what a rush!
its fine....but if you are in very cold areas continue to run the GM coolant
Old 09-12-2011 | 09:02 PM
McAllenSS's Avatar
I live in deep south Texas(rarely gets below freezing during the winter). It currently is filled with dex-cool. How much water wetter do I pour in the Maggie's reservoir?
Old 09-12-2011 | 09:09 PM
It says right on the bottle, so many ounces of WW for each gallon. It's not much.
Old 09-12-2011 | 09:14 PM
Rick_Vor's Avatar
You only use 1oz per Quart so it goes a long way. As Moregrip said, it's not an anti-freeze so your tamk will freeze below 32*.
Rick
Old 09-13-2011 | 09:51 AM
bud8fan's Avatar
water wetter is good stuff..i use it and a super coolant.
Old 09-13-2011 | 10:18 AM
EVILGMC's Avatar
i run distilled water and water wetter, plus a little bit of dex cool to keep the scale buildup to a minimum
Old 09-13-2011 | 11:28 AM
BlownChevy's Avatar
blownerator
Water Wetter does do much in the lower temperatures in the intercooler system.
Old 09-13-2011 | 11:32 AM
McAllenSS's Avatar
Thanks guys for your quick responses. One last question, does anyone know the coolant capacity of the Maggie's system? I'm guessing no more than a gallon?
