weak ass hemi
The cross-over is like 3/16" ID, much too small to risk a motor on. But easily fixed. Sunco has upgraded clutch kits, but as stated earlier Sharadon uses the same clutches but more of them. They also have the only available modified valvebody.
Well, maybe not exactly easy. I believe the 6.1 rails have a larger crossover but will need modifying since the feed is from the passenger side instead of driver's side like a truck uses. I have the stock 5.7 rails but brazed AN fittings on the ends eliminating the cross-over. (part of new return style fuel system) Aeromotive also makes larger rails as I am sure other outfits do.
