Were to get a intercooler for my whipple
Old 11-26-2009 | 11:04 PM
  #41
MikeGyver's Avatar
Originally Posted by SincalT/A
MB 271...
Now I'm being argumentative: That one has a clutch on the compressor, bad example.
Old 11-27-2009 | 01:25 AM
  #42
SincalT/A's Avatar
Man for not wanting to be argumentive you sure are.Then you rub it in with (Bad example).Before you discredit my statements make sure your right.
After the use of a clutch controlled kompressor on the 271.MB switched to a ECU controled BPV.Which how mine is currently is jus not ecu controlled its vacum referenced.
I am not some young kid that knows a little bit about PD blowers.I have spent almost 2yrs.researching and F-in with my setup and a few others to figure this out.By reseaching I mean couple hrs. every day on the net or in the garage tinkerin.It has taken me so long cause 1 Im self taught 2 I Have a terrible memory and have forgot more than I've learned3.I just don't have a lot of throw around money.The only thing I do have going for me is a good amount of determination.Its cool man cause all you guys do is fuel it with your nay say That's why I didn't post about till now I knew I would catch some flack.
Old 11-27-2009 | 04:15 AM
  #43
03sierraslt's Avatar
Easy man, I am not saying ****. I am always interested in new thoughts. I was determined to make things work, where do you think the original intercooler twin screw thread came from? I am not saying I think it wouldn't work and I am not saying I think that it would work. However I do want to know more. By now you should have learned you are going to take flack because you own a Whipple, same here with my KB....
Old 11-27-2009 | 10:43 AM
  #44
SincalT/A's Avatar
Sorry that was jus a stupid rant it was late and I was tired.No matter what I will share with you guys what happens good or bad.
Old 11-27-2009 | 12:35 PM
  #45
MikeGyver's Avatar
Thanks. I was just twisting your nipple to try and get you to spill more info.
Old 11-27-2009 | 01:31 PM
  #46
SincalT/A's Avatar
Well you got the sensitive one ********.
Old 11-27-2009 | 03:27 PM
  #47
06chevy5.3's Avatar
I have the same setup a intercooled kenne bell.... and have some simular problems slow throttle response and poor idle.....
I'm thinking of using a speed density tune and takeing the maf out or moving it to the charged side of the intake so the engine is not responding off a reading so far the the engine
Does porting the intake of the charger and bigger throttle bodies make that big of a difference 10-15 hp
Old 11-27-2009 | 09:45 PM
  #48
Running 2barSD makes a HUGE difference in throttle response with the way ours is setup. I will never run a MAF on my setup since switching. Throttle response is nite and day different. Not sure about your idle issue, mine idles fine.
Old 11-28-2009 | 12:10 PM
  #49
06chevy5.3's Avatar
It dies alot when coming to a hard stop or turning and braking........ I have a TH400 trans so the computer has no idea what the trans is doing anymore which is part of the problem
Old 11-28-2009 | 12:24 PM
  #50
Thats also a decent size cam for a 5.3, what LSA is it?
Quick Reply: Were to get a intercooler for my whipple
