What
OK so right now my list looks like this,
Aeromotive center in/out 340 pump
Tricks e-fans
Siemens 60#'s
Mini Delphi to ev1 adapter
4" bullet and a u-bend
And I think that's about it, what kind of spacer will I need for the fuel rail?
Tricks e-fans
Siemens 60#'s
You can buy a digital caliper pretty cheap from harbor freight. Just cut an aluminum dowel rod to size and drill a hole through it. There is a lot of little parts that you need to piece together a turbo kit. Don't forget your oil line fittings, vacuum hoses, extra hose to reroute the heater hoses, how are you doing your pcv system?, longer bolts for the fuel rails, etc...
