What
Old 03-06-2012, 10:30 AM
  #21
JoeyGC5's Avatar
On my 05 I just ran the intank 255 with stock returnless system. I didn't have any issues until around 12lbs of boost, then over that a return system and bigger pump would've helped me
Old 03-06-2012, 11:57 AM
  #22
kode-x-kustoms's Avatar
OK, I only plan to run around 10#'s just cuz this truck is regularly driven by other people and is still used as a work truck.
With the return less style would I be gaining anything going with the 340 vs a 255?
Old 03-06-2012, 10:25 PM
  #23
JoeyGC5's Avatar
Either pump would work, but I'd try the 340 as it's able to supply more volume at higher loads and the prices should be pretty damn close, imo.
Old 03-07-2012, 05:48 AM
  #24
The 340 is 100$ more.
OK I think I might order the fuel pump, wb, and boost gauge today. I'm also going to talk to a friend of mine that has some connections at a few local salvage yards about getting me some e-fans.
Old 03-08-2012, 11:38 AM
  #25
Alpinestar's Avatar
Originally Posted by kode-x-kustoms
You mean as in a catch can for the PVC?
yea the catch can or how ever you decided to do it
I would put a 3-5lb. spring in the wastegate and run a manual boost controller under the hood. If you have efi live I would leave it in valet mode in addition to low boost while other people are driving it. The bigger pump is just capable of supporting more HP.
Old 03-08-2012, 11:52 AM
  #26
THE-HOE's Avatar
and like someone said on the first page, there's complete plug and play 60lb Inj for trucks. I ran them for a few years with no issues.
Old 03-11-2012, 06:22 PM
  #27
OK guys I'm getting everything ordered.
What would be the quickest/cheapest way to do the pcv system?
